Gathering Interest
A DropFeatureCache tranformer
Related products:FME Form
mariuszwojcikgb
martin_ekstrand
maddiel
geomancer
danilo_fme
+11
  • mariuszwojcikgb
    mariuszwojcikgb
  • martin_ekstrand
    martin_ekstrand
  • maddiel
    maddiel
  • geomancer
    geomancer
  • danilo_fme
    danilo_fme
  • sigtill
    sigtill
  • ewoudvdc
    ewoudvdc
  • carlm
    carlm
  • mmccart
    mmccart
  • jatoxa
    jatoxa
  • crutledge
    crutledge
  • ronnie.utter
    ronnie.utter
  • frro
    frro
  • mattatsafe
    mattatsafe
  • sujitbhunia
    sujitbhunia
  • arenscott
    arenscott
ronnie.utter
In large and complex FME workspaces, memory usage can become a major performance bottleneck, especially when feature caching is enabled for debugging or when large feature streams are processed sequentially.
It would be incredibly useful to have a dedicated transformer (e.g., DropFeatureCache, ClearMemory, or similar) that can be placed mid-flow to explicitly clear cached data, or release memory from earlier processing paths.
This would be especially helpful in long chains of transformations, loops, or branching logic where intermediate data is no longer needed but still retained in memory.
JennaKAtSafe
NewGathering Interest
JennaKAtSafe
Hi ​@ronnie.utter, thanks for raising this pain point. We’re working on some exciting changes to how Feature Caching works. While it may not take the form of a dedicated transformer like the ones you’ve suggested, I believe it will help alleviate some of the concerns around heavy memory usage.
ronnie.utter
Forum|alt.badge.img+11
  • April 17, 2025
Thank you for your answer. Looking forward to review the development ☀️
ronnie.utter
  • April 17, 2025
@JennaKAtSafe ,One thought I also have is this: Is it true that unused output ports, such as in the FeatureMerger, still store cache or use memory? If so, would a function like enabe a "Clear data from unused ports" option in the transformer help? Could this be a good setting to use?
JennaKAtSafe
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
JennaKAtSafe
JennaKAtSafe
@ronnie.utter Yes, I can confirm that currently, feature caching occurs for disconnected ports and will take time during workspace execution, as it writes files to disk. However, this doesn’t necessarily increase the process’s memory usage, since each feature cache acts as an on-disk terminus — meaning the features don’t need to be held in memory beyond that point.
