Open
AttibuteManager: Rename attribute "sub-properties" (attr.hyperlink, attr.formatting, etc.) alongside the attribute itself
Related products:Transformers
  • November 28, 2024
  • 20 views
9val
danilo_fme
warrendev
panda
philippeb
+20
  • 9val
    9val
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • panda
    panda
  • philippeb
    philippeb
  • milo89
    milo89
  • spatialexjames
    spatialexjames
  • kumudan
    kumudan
  • s.jager
    s.jager
  • martin_fme_user
    martin_fme_user
  • chk1
    chk1
  • flavien
    flavien
  • mvanwie
    mvanwie
  • majkiboy
    majkiboy
  • nzmalc
    nzmalc
  • dannymatranga
    dannymatranga
  • ares
    ares
  • jpvo
    jpvo
  • paulh
    paulh
  • seanf1spatial
    seanf1spatial
  • stuiew
    stuiew
  • oliverquirke
    oliverquirke
  • laplanter
    laplanter
  • p_c_20
    p_c_20
  • erik.ahlm
    erik.ahlm
vlroyrenn
When using ExcelStyler early on in your flow (I use it to highlight invalid values in Excel fles right after the data has been read from my database) or any transformer that creates <attributename>.something “sub-attributes” (not sure what the actual name would be), you currently must make sure to manually rename all of those alongside the main attribute whenever you rename them through an AttributeManager or AttributeRenamed, otherwise they will not be observed by downstream writers and transformers. If the Styler is added in the later stages of building the flow, that means going through all downstream AttributeManagers one by one to make sure the newly added sub-attributes follow the main one.
It would be conveinient if those could all be renamed together automatically whenever the main attribute is renamed.
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
NewOpen
danilo_fme
Forum|alt.badge.img+45
  • April 16, 2025
LizAtSafe wrote:
NewOpen
Thanks for update.
