Open
Lists - Extract Element Range
Related products:Transformers
  • November 17, 2024
  • 5 replies
  • 82 views
hkingsbury
danilo_fme
joy
alexbiz
+1
  • redgeographics
  • hkingsbury
    hkingsbury
  • danilo_fme
    danilo_fme
  • joy
    joy
  • alexbiz
    alexbiz
  • nia.colebrooke
    nia.colebrooke
chriswilson
Or ‘list slicing’ of course.  For example this list with element positions also as values for illustration:
List[0,1,2,3,4]
A following AttributeManager wants to extract:
Attribute1 = List{0} so would retrieve the value of ‘0’
Attribute2 = List{1} would retrieve ‘1’
Attribute3 = List{2:} or {List{2:5} or List{2:-1} would retrieve ‘2,3,4’
Doing this without python would save time and also those without python skills would benefit.  I am aware of the ListSlicer and ​@takashi could correct me if I’m wrong but it doesn’t quite seem to achieve this if the element range is open-ended or goes from e.g. element 2 to the end of the list.  Maybe it’s just an enhancement to that transformer?
A ListIndexRetriever type transformer might be a good way to do this, or bake it into attribute transformers in addition to the current single-element functionality.
chriswilson
Forum|alt.badge.img+11
  • November 22, 2024
Just correcting the second example for Attribute3 - this would be List{2:4} in this case
geomancer
Forum|alt.badge.img+48
  • November 22, 2024
Have you looked at the ListElementExtractor from FME Hub?
chriswilson
  • November 26, 2024
It needs to be able to extract a slice that is open-ended e.g. from an index to the end of the list, into one attribute.  The ListElementExtractor and Takashi’s ListSlicer don’t cover the functionality I’m suggesting.
geomancer
  • November 27, 2024
You can remove the superfluous list elements with a BulkAttributeRemover, and use ListConcatenator to combine the remaining list elements into a single attribute.
The regular expression used in the example below is _IDs\{[0|1|2|3]\} (the list is named _IDs, the list elements ro remove are 0, 1, 2 and 3, and the curly brackets need to be escaped with a \ because they have a special meaning in regular expressions).
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
NewOpen
