Archived
Find and Replace function for given attribute
Related products:FME Form
  • September 18, 2024
  • 53 views
vlroyrenn
danilo_fme
mikev
geoportalcartog
  • vlroyrenn
    vlroyrenn
  • danilo_fme
    danilo_fme
  • mikev
    mikev
  • geoportalcartog
    geoportalcartog
judith
Observer
renaming an attribute in large workspaces oftentimes takes a lot of time because of the related manual adjustments needed.
I would appreciate a function that is able to change a given attribute to another given attribute within a whole workspace in every Transformer and Writer.
Best regards
Judith
bwn
Forum|alt.badge.img+26
  • September 19, 2024
Similarly would note that this is desirable but there is an existing Transformer that almost does this already: NullAttributeMapper
NullAttributeMapper is currently mis-named.  It actually does do All/Selected Attribute search and replace for more than just Nulls.  It will look for any fixed value, or any RegEx pattern.
What it is missing, is the ability to use the current attribute value in the replacement function, + more broader comparator support such as > , < , LIKE, IN() etc.  Otherwise it is actually very close to an “All Attribute Search/Replace”
denniswilhelm
Forum|alt.badge.img+11
The result might be the same, but it’s only a hotfix and the workspace will only get more complicated.
I think the initial idea is more about refactoring Workspaces and therefore changing all occurences of specific elements (like attributes) throughout the Workspace. If you rename user parameters then the change will be applied everywhere. This is different with attributes. If I change an attribute early in the Workspace all following transformers will be invalid.
I guess a more general idea would be to provide a Search & Replace funtionality. Right now you can only search for strings in FME Form, but a replace is missing.
LizAtSafe
Forum|alt.badge.img+15
Updated idea statusNewArchived
Idea merged into:
All the votes from this idea have been transferred.
