Released
RasterConvolver support band selection
Related products:FME Form
jdh
I'm really excited about the RasterConvolver transformer in the 2018.1 beta. However it applies the convolution filter to all bands. It would be nice if this transformer supports band selection and only applies the convolution filter to the selected bands.
mark2atsafe
Forum|alt.badge.img+44
I think the transformer does support band selection. Use the RasterSelector transformer before it to do that. I tried it and it worked fine for me. Let us know if it doesn't work for you.
jdh
Forum|alt.badge.img+28
  • June 19, 2018
It does in the latest beta, so that's great. The documentation should be updated though, since it says "after applying a convolution filter to all the bands." and doesn't contain the standard "Usage Notes
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection." that other transformers that support band selection do.
mark2atsafe
We're just about to start overhauling all of the raster transformer documentation, so I'll make sure that info goes into there.
