Adding authorization header token support to data streaming, job submitter, data download services. Possibly by aligning or incorporating them into the REST API via the transformations api.
For example:
POST /transformations/submit | transact | transactadata/<service>/< repository >/< workspace >
Or maybe through a new Services Manager API?
I am happy to note that as of FME Server 2018.0 (Build 18267) and 2018.1 (Build 18415), we have supported tokens in the Authorization header.
HeaderValueAuthorization
fmetoken token=<token>
For those of you running newer versions of FME Server – you will notice we provide this documentation when going through the 'Create Webhook' workflow.
Authorization with Header is documented in FME Server'
