But congrats!!! The data inspector on cached data is BLAZING fast. ;)
Archived
Right click on Mac picks first option automatically
On a Mac, and only in FME 2019, if you right click and the mouse moves at all the first select of the dialog is picked. This is using a MagicMouse and I have gone through all forums (Mac and Safe) to see if there was some kind of fix. This was an issue before but appeared to have been fixed in 2018.1 but has now come back causing a lot of accidental cutting deleting inspecting. I have a VM on the same machine running in Windows and do not have the same issue.
