Installing FME Server 2018sp1 to a different drive still installs some files on C:\Program Files\Common Files\...\
This is a problem for us in our enterprise environment since we do not have authority to save files to C: drive (we use our own allocated space on E: drive). Is there way we can get all those files to install under our selected drive (E:) instead of C:?
laurawatsafe
Forum|alt.badge.img+11
Hi @lbohy That shouldn't be happening. What files are being installed to that location when you run the FME Server installer?
richardatsafe
Forum|alt.badge.img+10
If a user starts an express install and then changes to a distributed installation without exiting the installer the install folder can be split between the two specified directories, but if you only follow one path distribute or express this shouldn't occur.
  • August 2, 2018
Hi Laura,
I'm seeing files write to C:\\Program Files\\Common Files\\Server\\fme\\Safe Software Shared directory. In there are 2 files and 1 folder:
files:
FMECOMUtil.dll
FMEShellExt2.dll
Folder:
FME Objects (I'm sorry to say I didn't look in here).
FYI, We're installing on a Windows 2016 server with the latest release download of FME Server 2018 sp1.
laurawatsafe
lbohy wrote:
Hi Laura,
files:
FMECOMUtil.dll
FMEShellExt2.dll
Folder:
Thanks @lbohy! We'll check into this and get back to you here.
laurawatsafe
lbohy wrote:
Hi Laura,
files:
FMECOMUtil.dll
FMEShellExt2.dll
Folder:
Update: I've replicated this problem when testing with an Express installation. We're looking into it. Thanks for reporting this!
