Hello, Are there still no plans for FME2022 to support Ubuntu 22.04 ? In other question it was mentioned that FME2023 will support Ubuntu 22.04. When is the release planned ? Thanks!
Best answer by markatsafe
@davis_ermanis​ Ubuntu 22.04 will be supported in FME 2023 beta releases starting build 23217 - which should be posted in the next day or so (current beta is 23216).
nielsgerrits
Forum|alt.badge.img+54
From the article FME Release Process and Versioning
All major releases are scheduled, with typically 3 a year - one every four months - we target our major releases around the months of March (x.0), July (x.1) and November (x.2).
This is probably the related question.
Thanks for info. So I can presume, that FME2023 will come out sometime in this march.
Yes, that is the related question.
Can you also confirm that Ubuntu 22.04 will be supported ? A bit confused about it, because currently the FME2023 beta is available on Ubuntu 20.04 not 22.04
  • January 27, 2023
