FME Server Web UI and the Firewall
  • October 24, 2016
  • 111 views
fmelizard
Forum|alt.badge.img+18
What ports do I need to open on my firewall to ensure I have full functionality of the FME Server WebUI?
Best answer by steveatsafe
For full functionality of the FME Server Web UI you'll need to open port 80 (if https port 443) and port 7078. Port 7078 is for topic monitoring which uses websockets.
steveatsafe
Forum|alt.badge.img+12
  • October 24, 2016
mattwilkie
Forum|alt.badge.img+11
  • February 14, 2023
Run from an elevated CMD or Powershell:
netsh advfirewall firewall add rule name="Open Port 80" dir=in action=allow protocol=TCP localport=80
netsh advfirewall firewall add rule name="Open Port 443" dir=in action=allow protocol=TCP localport=443
netsh advfirewall firewall add rule name="Open Port 7078" dir=in action=allow protocol=TCP localport=7078
netsh advfirewall firewall add rule name="Open Port 80" dir=out action=allow protocol=TCP localport=80
netsh advfirewall firewall add rule name="Open Port 443" dir=out action=allow protocol=TCP localport=443
netsh advfirewall firewall add rule name="Open Port 7078" dir=out action=allow protocol=TCP localport=7078
I don't know why this is left as an exercise to the user. It's straightforward once the command parameter synax is sorted out.
