Writing issue after Date time convertor
abnan0001
Forum|alt.badge.img+7
Hi FME Community..
Need your guidance , I'm receiving different dates in a particular column called "date_1" total records 401 including null when im using date time convertor to standardise it , Give me all null values to that column..
Need expert Guidance
I have attached the template
Thanks
Best answer by david_r
Try using the following input format descriptor in the DateTimeConverter:
%m/%d/%Y %H:%M
  • June 19, 2023
%m/%d/%Y %H:%M
abnan0001
  • June 21, 2023
Thanks David ..
It's Solved
Thanks Again
