Unable to connect an SFTP server with a *.ppk Key
  • Oct 17, 2022 10:09 AM UTC
  • 200 views
gemeentehw_mvk
I am not able to connect to a SFTP server with FME Server. I have used the following description Using a private SSH key with FTPCaller to authenticate an SFTP Connection on FME Server and FME Desktop (safe.com) to create the workspace. The Workspace runs fine but after I uploaded to FME server and run it with FME Server, I get a "login denied" error.
Version 2022.1
richardatsafe
Forum|alt.badge.img+11
Hi @gemeentehw_mvk​ ,
It sounds like the error in the log file is because the service account running the FME Server processes does not have permission to load the SSH keys. If you can run the scripts as the FME Server user, you might be able to debug the permissions.
gemeentehw_mvk
@richardatsafe​  Thank you for your comment. We're going to investigate.
