Total Seconds hh:mm:ss for fields over 24 hours
  • Nov 27, 2023 1:15 PM UTC
  • 9 replies
  • 174 views
Hello – I am hoping someone can help.
I asked a similar question previously and got a working solution:
https://community.safe.com/s/question/0D5Dm00001GWvsMKAT/calculating-total-second-from-hhmmss-field
However that solutions only works for hh:mm:ss fields that are under 24 hours as soon as that field is over the 24 hours I get a blank value.
@DateTimeDiff(@Value(Duration),000000,seconds)
Does anyone know of an alternative solution so it would calculate the total seconds for records under and above 24 hours?
Many,
Thanks
Best answer by nielsgerrits
Oh, AttributeSplitter is even better than the sub StringExtractor
When doing calculations, you need to add @Evaluate(), else it will be handled as a string expression.
So you need to do...
@Evaluate(
@Value(Time{0})*60*60+
@Value(Time{1})*60+
@Value(Time{2})
...when using an AttributeSplitter or...
@Evaluate(
@SubstringRegularExpression(@Value(Time),(\d+):(\d+):(\d+),0,1)*60*60+
@SubstringRegularExpression(@Value(Time),(\d+):(\d+):(\d+),0,2)*60+
@SubstringRegularExpression(@Value(Time),(\d+):(\d+):(\d+),0,3)
...if you do it using the regex sample from @geomancer​ or...
@Evaluate(
@Substring(@Value(Time),0,2)*60*60+
@Substring(@Value(Time),3,2)*60+
@Substring(@Value(Time),6,2)
...when using the substring function as @virtualcitymatt​ suggests.
I think using a substring might the best answer as you can do it in one go and substring is probably faster / less complex than regex?
nielsgerrits
Forum|alt.badge.img+67
So your data looks like...
25:62:62
...and you need...
93782
...seconds? Then split the string with an AttributeSplitter based on : and use an AttributeCreator to do (hours x 60 x 60) + (minutes x 60) + (seconds).
itsmatt
Forum|alt.badge.img+48
  • Nov 27, 2023 1:34 PM UTC
Ohhh thats an interesting one - I'm not 100% sure if this is supported or not by FME's built in DateTime tools.
perhaps @nielsgerrits​ has a clue if it is.
Another option, all be it much less ideal is to extract the various parts of the string and use an ExpressionEvaluator to calculate the number of seconds.
You can use the SubstringExtractor to create new attribute _hours, _mins_secs
and then the ExpresisonEvaluator to do the math
itsmatt
  • Nov 27, 2023 1:35 PM UTC
25:62:62
...and you need...
93782
nielsgerrits
I think it is doable in one AttributeCreator using regex to find the 3 inputs from the string, but I could not find the time to write it out.
geomancer
Forum|alt.badge.img+71
  • Nov 27, 2023 5:00 PM UTC
Sure 😀
Catching matches is probably easiest:
@SubstringRegularExpression(@Value(Input),(\d+):(\d+):(\d+),0,1)*60*60+
@SubstringRegularExpression(@Value(Input),(\d+):(\d+):(\d+),0,2)*60+
@SubstringRegularExpression(@Value(Input),(\d+):(\d+):(\d+),0,3)
Hey @geomancer​ when I try this I get this result: image@nielsgerrits​ I get also this result when splitting the field into hours minutes and second and using this formula
(@Value(QueueWaitH) * 60 *60) + (@Value(QueueWaitM) * 60) +@Value(QueueWaitS)
any ideas why?
thanks for all the help!
nielsgerrits
  • Nov 27, 2023 6:02 PM UTC
@Evaluate(
@Value(Time{1})*60+
@Value(Time{2})
@Evaluate(
@Evaluate(
@nielsgerrits​  that worked perfectly - thank you very much :)
geomancer
  • Nov 28, 2023 6:22 AM UTC
FME will automatically use @Evaluate when you use the Arithmetic Editor.
