The DateTimeConverter format y%#### does not work the way I understand it should. Please help.
  • December 13, 2023
  • 35 views
deanr
I am sending this date, Oct-23, through the DateTimeConverter. I have set t he input format as %b-%y2099. The DateTimeConverter is failing to parse the date with the message "Attribute(string: UTF-8)         : `fme_expression_warnings{0}.message' has value `Failed to evaluate expression '@DateTimeParse(Oct-23,%b-%y2099,repair)'. Result is set to null'".
What am I doing wrong?
I have attached a sample project that demonstrates the failure.
My FME Form version is FME(R) 2023.1.1.0 (20230928 - Build 23631 - WIN64).
https://docs.safe.com/fme/2023.1/html/FME-Form-Documentation/FME-Transformers/!Transformer_Parameters/Date-Time-Functions.htm#Format
Best answer by deanr
I solved my problem. The input string appears to need a day inserted, e.g., Oct-23 -> Oct-01-23.
deanr
  • December 13, 2023
