Testing the existence and absence of values
  • Oct 2, 2020 12:22 PM UTC
  • 106 views
I have two tables - the first lists a series of attributes and values against equipment
And the second lists the expected attributes that should be listed against each equipment type
I need a way of telling which are present, but more importantly which are not. So in this example
Equipment 5 is complete
Equipment 10 is missing Sum
Equipment 15 is missing Count
Ultimately I need to get a score
Sample 100% exists
Sum 0% exists
Count 50% exists
The bit i'm really struggling with is the absence of things since the equipment table is huge and the requirements differ for each equipmenttype
Thanks for your help
  • Oct 2, 2020 1:01 PM UTC
Stepping way from things always helps an idea to pop into your mind..
Think this does it
Answered
  1. It starts off with a sampler and statisticscalculator. these work out how many of each Equipment Types I have
  2. This is FeatureMerged with the table of required attribute names to work out how many of each attribute there should be in my equipment table
  3. A StatisticsCalculator works out how many there actually are
  4. The two are featuremerged together where equipmenttype and attributename match
  5. An attributemanager updated any unmatched with a count 0 since it is not present
  6. An expressionevaluator calculates the difference to give me a % present
