Tester send Email for Passed when Passed has returned no records?
  • Jan 6, 2024 2:25 AM UTC
  • 100 views
vxn43
Forum|alt.badge.img+20
The data I am working is real time vehicle AVL GPS data that is dumped into a Feature Class using ArcGIS GeoEvent Server. The Point Feature Class has 104 records.
My objective is to have my workspace act as a "listener" and send me an email every day M-F @ 10a letting me know that GeoEvent Server is reading these records.
Of the 104 records (more records are added each month, so 104 is not static), there are 17 that are not the current date so they are routed to Failed in the Tester. There will always be records in this data that are not the current date.
My question relates to the Tester, the way I have my workspace set up now, is if there are no records in Passed and all 104 records are routed to Failed, I will not get an email. Is there another transformer that needs to be added or maybe a parameter change in one of the existing transformers in my workspace? I want to also get an email if no records are routed to Passed, is this possible?
Best answer by DanAtSafe
Hi @timh​ Use the NoFeaturesTester from the FME Hub.
DanAtSafe
Forum|alt.badge.img+23
  • Jan 6, 2024 7:46 PM UTC
