replace raster cell negative values with abs(value) is it possible?
oliver.morris
Forum|alt.badge.img+12
I would like to replace any negative raster cell values with their positive equivalent either using abs(value) or another other means. Is this possible with a transformer, can I obtain the cell value and use rastercellvaluereplacer?
Thank you for your help
Best answer by ebygomm
Have you looked at the RasterExpressionEvaluator?
Forum|alt.badge.img+32
  • August 18, 2020
oliver.morris
  • August 18, 2020
Thanks that worked perfectly.
oliver.morris
  • August 18, 2020
Capture
