Remove space between numbers and letter in a column
  • Oct 21, 2022 8:42 AM UTC
  • 123 views
arash_hokm
Forum|alt.badge.img+8
I have a mix column that contains numbers and letters. in some records the first value or two first values ​​are number and then is a space then comes letter. the space und letter don't appear in all records. if a record contains this space I want to remove the space between number and letter.
For example : 2 a -> 2a oder 22 a -> 22a.
Best answer by ebygomm
This regex will match any space preceded by a number and followed by a letter.
(?<=\d)\s(?=[a-zA-Z])
If you use it in a StringReplacer with ReplacementText of nothing you should get the result you are after
Forum|alt.badge.img+54
  • Oct 21, 2022 8:49 AM UTC
arash_hokm
  • Oct 21, 2022 8:50 AM UTC
Thanks alot 🙂
