OpenAICompletionsConnector: Getting this error OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): An error occurred while accessing the URL 'https://api.openai.com/v1/completions'. This connector used to work in FME Form 2022.2. Any advise?
  • August 24, 2023
  • 38 views
angwan
imageLogs:
OpenAICompletionsConnector_2 Input Input Collector (TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
OpenAICompletionsConnector_2_Input1680804321 Input Splitter (TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
OpenAICompletionsConnector_2_ParameterFetcher (TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
OpenAICompletionsConnector_2_EmptyNumericValues (TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [3]: Starting HTTP upload to 'api.openai.com'. Expected transfer size: 411 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [3]: HTTP Upload: sent 411 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [1]: Starting HTTP upload to 'api.openai.com'. Expected transfer size: 411 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [1]: HTTP Upload: sent 411 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [2]: Starting HTTP upload to 'api.openai.com'. Expected transfer size: 414 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [2]: HTTP Upload: sent 414 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [1]: Starting HTTP download from 'api.openai.com'. Expected transfer size: 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [1]: HTTP Download: received 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [1]: HTTP transfer summary (api.openai.com): status code: 429, download size: 222 bytes, DNS lookup time: 73 ms, total transfer time: 393 ms
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [2]: Starting HTTP download from 'api.openai.com'. Expected transfer size: 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [2]: HTTP Download: received 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [3]: Starting HTTP download from 'api.openai.com'. Expected transfer size: 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [3]: HTTP Download: received 222 bytes
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [2]: HTTP transfer summary (api.openai.com): status code: 429, download size: 222 bytes, DNS lookup time: 73 ms, total transfer time: 405 ms
OpenAICompletionsConnector_2_HTTPCaller (HTTPFactory): [3]: HTTP transfer summary (api.openai.com): status code: 429, download size: 222 bytes, DNS lookup time: 72 ms, total transfer time: 406 ms
j.botterill
Forum|alt.badge.img+36
  • August 25, 2023
According to the FME hub for this transformer FME Hub (safe.com)  FME 2022.2.2.0 (Build 22782) or higher is required... So check your build is in fact higher.
FME Community (safe.com)
You can right click the transformer and edit. Then inspect where the 'https://api.openai.com/v1/completions' httpcall is located, referring to the API documentation API Reference - OpenAI API
