NullAttributeMapper...
simonhume
Participant
Hi
I'm hoping someone can help me with a query.
I have a SQL Server view that i am opening in FME; this contains both commercial and residential addresses
The view has 2 reference columns, one contains a Council Tax reference, the other a Business Rates reference
Some of the residential records do not have a Council Tax reference as they are not live properties; the reference column is NULL for these
I have used a NullAttributeMapper to change the NULL value to New Build, but all records with a NULL value are being changed, including the Commercial records
Is there a way of using the NullAttributeMapper to query 2 columns in the table so only NULL records that are residential. Or is there another transformer that would be more suitable?
thanks
Simon
Capture
Best answer by ebygomm
Instead of the NullAttributeMapper you can use an AttributeCreator or AttributeManager with a conditional query e.g. if Type = Residential and CTax is null, set value to 'New Build'
Capture
Forum|alt.badge.img+32
  • November 3, 2020
Capture
simonhume
Participant
  • Participant
  • November 18, 2020
Capture
@ebygomm​
sorry for the delay in replying. Your advice has worked thank-you
