Multiple SDE Connectionfiles in one workbench
  • Jan 6, 2021 3:24 PM UTC
  • 59 views
I have multiple SDE Connections files, which are used as datasources ("Reader") with the same workflow. Until now I have for every SDE Connection files a specific workbench. Is there a way to bring all SDE Connectionsfiles (as Reader) into one workbench (Loop?).
The easiest is a WorkspaceRunner.
Process
  • Workbench 1 - Text file with the connection names and WorkspaceRunner configured to use those names as a variable
  • Workbench 2 - The process you want to run left as is
Using this method you can run up to 7 of them at the same time if your server/pc can handle the load.
  • Jan 7, 2021 1:25 PM UTC
Process
Thanks a lot. I will try...
