Loading Parameter Manager
  • Dec 7, 2021 1:20 PM UTC
  • 57 views
damien
I have FME(R) 2021.1.2.0 (20210903 - Build 21627 - WIN64).
With this version, appears the Parameter Manager.
And I have big problem with it.
I often use a type "Choice" or "Choice Multiple" with a list of around 2000 or 3000 values. And sometimes more.
With FME 2019 I had no problem to configure it.
But with FME 2021, it takes several minutes to open the Parameter Manager, any modification takes a long time and sometimes, it's so long that FME crash.
It's very annoying because it worked great and I can't do without these lists.
Have you got a solution or a patch for this ?
Thank You
danilo_fme
Forum|alt.badge.img+58
  • Dec 9, 2021 12:24 AM UTC
Hi @damien​
I didn't have any problem to use Parameter Manager in 2021.
Maybe can it be memory in your machine. Did you check this paramenter ( memory )?
Thanks in Advance,
Danilo
damien
  • Dec 9, 2021 7:49 AM UTC
Hi @damien​
Thanks in Advance,
Danilo
Hi @danilo_fme​
Yes I check the memory and everything it's ok.
With the sames workbenchs with 2019 I have no problem.
And all my co-workers have exactly the same behviour, so I don't think that it comes froms the machines.
Damien
Forum|alt.badge.img+63
Hi @danilo_fme​
Damien
It sounds like something Safe's tech people would be very interested in seeing. I suggest you send your workspace in to support.
damien
  • Dec 9, 2021 1:43 PM UTC
Hi @danilo_fme​
Damien
I've just to create a empty workspace just with a parameter.
It takes 1m44s to open the window Parameter Manager...
And every modification in the manager takes a long long time.
With the same list in FME 2019 everything is instantaneous.
Thanks
