Issues connecting to ESRI portal via web service authentication
  • Sep 10, 2023 11:59 PM UTC
  • 416 views
josiahmillar
Forum|alt.badge.img+7
I am unable to connect to my organizations enterprise portal.
I have a web service connection that works for other members of my organization, but whenever I attempt to connect I get the error: "Type: 4, Number: 1, Message: Failed to get authorization query string."
I have tried everything that I, my boss, and my IT department can think of, but still no luck.
Any advice would be appreciated,
Cheers.
Best answer by saraatsafe
Hi @josiahmillar​, when did this error pop up? Has it been a while since this workspace has been run? If so, you may need to generate a new token by going to Tools > FME Options > Web Connections > right-click the connection and select "Reauthenticate".
If you haven't tried yet, you can also recreate the connection and see if that works. This article: How to Create an ArcGIS Enterprise Portal Web Connection will walk you through the setup.
saraatsafe
Forum|alt.badge.img+13
  • Sep 11, 2023 7:51 PM UTC
josiahmillar
  • Sep 11, 2023 8:08 PM UTC
Hey @saraatsafe that worked thank you! I just needed to reauthenticate. It was a brand new connection that I hadn't managed to get working in the first place, so I didn't think to reauthenticate, but it worked. Thank you :)
