Is there a recent issue with the Sentinel-2 on AWS reader?
abal
Hey there,
I recently tried to run a workspace I created a month ago where I download the latest Sentinel-2 image via the FeatureReader (Sentinel-2 on AWS format) based on an intersection with a shape file. The workspace used to work out fine.
Now, the workspace fails early at the FeatureReader with the following error message:
Imagery on AWS Reader: Error listing 'http://sentinel-s2-l1c.s3.amazonaws.com/?delimiter=/&prefix;=tiles/32/U/MC/'. Check the reader filters or try again later. The error was 'FMEException: 931363: Imagery on AWS Reader: Error downloading 'http://sentinel-s2-l1c.s3.amazonaws.com/?delimiter=/&prefix;=tiles/32/U/MC/'. Check the reader filters or try again later. The error was '403 Client Error: Forbidden for urlhttp://sentinel-s2-l1c.s3.amazonaws.com/?delimiter=/&prefix;=tiles/32/U/MC/''
Does anyone encountered the same error message? Is it possible that the imagery downloading service is temporarily unavailable or did it changed the permissions (regarding the the 403 Client Error)?
Cheers,
André
EDIT: In addition, the Landsat-8 and Sentinel-2 selector at the Server Playground demos (http://demos.fmeserver.com/landsat-sentinel-selector/) only provides Landsat-8 images for a given location (tested in Vancouver and Northern Germany).
Best answer by jdh
Sentinel-2 data on amazon is now on a pay per use system.
See https://forum.sentinel-hub.com/t/changes-of-the-access-rights-to-l1c-bucket-at-aws-public-datasets-requester-pays/172 for details.
jdh
Forum|alt.badge.img+28
  • August 13, 2018
fmelizard
Forum|alt.badge.img+18
  • August 14, 2018
Thanks for letting us know @jdh -- I've asked the team to see how we can change our reader to include AWS credentials.
abal
  • August 14, 2018
Thank you for the information, @jdh!
Could this have a massive impact to the free, full and open data policy of Copernicus/Sentinel, @daleatsafe? Could you or the team suggest another workaround to get Sentinel data?
jdh
  • August 14, 2018
As far as I am aware, the copernicus scihub has no intention of becoming pay to play.
You can access sentinel data for free from https://scihub.copernicus.eu/.
Use the open hub for an interactive session, and the api hub if you want to script your data access.
Both require a free registration.
  • August 24, 2018
Has anyone any experience with using for instance the httpcaller transformer for downloading from scihub via FME? And wants to share it? :-)
abal
  • August 24, 2018
Hey @andeh, I'm currently working on this thing. I will share my solution within next week!
  • August 24, 2018
Many thanks @abal! Excited to see what you come up with:-)
fmelizard
  • August 26, 2018
Just saw that a fix will be put into FME 2018.1.x shortly -- will be available by early Sept. latest.
Same issue, would love to see a scihub x FME workflow solution. :)
jdh
  • August 29, 2018
So I had a bit of time today and decided to put together a scihub custom transformer for downloading Sentinel-2 imagery. sentinel2querier.fmx
This is a beta version, and I don't guarantee it will work in all circumstances, feedback is welcome.
This transformer does not immediately download the data, it creates footprints for all images that intersect the area of interest (trigger polygon) that meet the criteria (date range and cloud cover).
These footprints contain all the metadata available for the image as well as an explicit url to download the full version of the data (_data_URL).
@andeh , @harijsijabs , @abal
xiaomengatsafe
Forum|alt.badge.img+3
Update: The Sentinal-2 AWS reader now allows user to supply s3 credentials for access. The updated feature can be found in our latest 2018.1.0.2 available here.
abal
  • November 22, 2018
Just arrived in the FME Hub: The SentinelDownloader Transformer:
https://hub.safe.com/transformers/sentineldownloader
This looks like a pretty good alternative to the SentinelQuerier since it outputs the data bandwise and let you automate upcoming processes.
