Is it possible convert milliseconds to %Y-%m-%d %H:%M:%S?
  • Mar 7, 2023 11:41 AM UTC
  • 121 views
david_
Forum|alt.badge.img+8
How I can convert milliseconds (for example: 1663767945000) to %Y-%m-%d %H:%M:%S ?
I tried with a DataTimeConverter transformer but it doesn't detect the input format.
Any ideas?
Thank you.
Best answer by david_r
You can divide the milliseconds by 1000 and send it into the DateTimeConverter with something like:
imageResult:
1663767945000 -> 2022-09-21 13:45:45
  • Mar 7, 2023 11:59 AM UTC
imageResult:
david_
  • Mar 7, 2023 1:38 PM UTC
Hi @david_r​ , thank you for your quick answer!
Have you tried running your example? I did the same but the DateTimeConverter reject the execution.
milliseconts with datetimeconverter
david_
  • Mar 7, 2023 1:41 PM UTC
Hi @david_r​ again, sorry, it was my fault.
I don't know why the dateTimeConverter set the Datetime Attibutes as "@Value...". Now it is working.
Capture2
Thanks a lot!
Regards.
  • Mar 7, 2023 2:01 PM UTC
Capture2
Thanks a lot!
Regards.
Good to hear. The @Value()-thing is due to a (very annoying) bug, I believe it's been fixed in later versions.
