How to write stuff to the Log?
nicholas
Forum|alt.badge.img+14
I would like to write some messages to the Log, at the end of a successful Translation.
For example, the source schema & table name and the destination schema & table name
Is there a FME Transformer that can write a user parameter to the Log? With some surrounding text?
Forum|alt.badge.img+55
Easiest way is to use the Logger transformer, that allows you to log a custom message. Do keep in mind that that message is logged once per feature passing through.
Alternatively, a Python shutdown script, which will be executed after the processing.
nicholas
  • July 26, 2023
I do not want to write a message for every single feature.
I just want to write a message to the log when the Translation is successfully finished.
By Python shutdown script, do you mean the PythonCaller?
And that I should use a Print statement here?
  def close(self):
    pass
No, it's in the Navigator:
Workspace Parameters -> Scripting -> Shutdown Python Script
There's a good knowledge base article that should help you on your way: https://community.safe.com/s/article/shutdown-python-scripts-in-fme
nicholas
  • July 28, 2023
I can now successfully use the Shutdown Python Script to print a message to the Translation Log window
Now I need to figure out how to convert a Published Parameter into a string so that it can be printed.
User Parameters are;
sourceSchema
TableName
destSchema
But Print (sourceSchema) fails
nicholas
  • July 28, 2023
I think I got it
import fme
sourceSchemaVal = "Source Schema : " + fme.macroValues['sourceSchema']
print (souceSchemaVal)
