I have to read several shapefiles that are in a second level zipped file. As an example:
C:\\compressed1.zip \\compressed2.zip\\ layer.shp
I get to reach the first level but when I try to reach the second level, FME gives me failures.
Any idea? Thank you very much
Best answer by nielsgerrits
Not sure if this can be done with a Reader/FeatureReader but you can use the ZipExtractor from the FME hub to achieve this.
"If you set "Yes" to the "Unzip Nested Zip Files Recursively" parameter, this transformer unzips all the nested zip files recursively."
It's not exactly what I want to do, but your review is a great help and with a Tester I've managed to do it.
Thank you very much for your help.
37 votes
24 votes
23 votes
21 votes
15 votes
11 votes
10 votes
8 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
