How to make Heat Maps/Hot Spot Maps in KML using FME Workbench
  • Nov 28, 2023 11:05 PM UTC
  • 383 views
maaw306
Participant
Hi all,
I'm new to FME and there is a lot to learn. I have been trying to research into how to generate a heat map (Hot Spot Map) in KML for Google Earth using FME Workbench (2019.2). I can't find an approach or forum that explains how to do it. Could anyone provide some tips on the process of transformers required to generate this? I currently have all my data plotted on Google Earth, I want to transform the plots into heat maps of dense areas.
If anyone has knowledge on this, I would love to discuss this. Thanks in advance!
edgarbaculi
Forum|alt.badge.img+4
