How to divide polyline which have Arcs to line and arc
  • January 15, 2016
  • 129 views
pratap
Forum|alt.badge.img+11
Hi FME Users,
I have a GDB file. There is a line feature class which have line+arc+line. When we select it selects as 1 feature (just like polyline in autocad). I want to divide as line,arc,line.
Any suggestions...
Thank you
Pratap
  • January 15, 2016
I think a geometry consisting of lines and arcs must be an IFMEPath object. If my understanding is correct, it can be decomposed into individual segments with the PathSplitter, and then you can separate lines and arcs with the GeometryFilter.
The GeometryPartExtractor may also be used, instead of the PathSplitter.
pratap
  • January 15, 2016
Thank you
Both worked well
Pratap
Forum|alt.badge.img+7
Hi Pratap,
I would use the PathSplitter combined with the GeometryFilter.
The PathSplitter decomposes a path in its segments. The GeometryFilter can then be used to split those segments based on their geometry.
