how can i Read data from API log File
  • Dec 6, 2022 8:24 AM UTC
  • 160 views
asadamjad
Participant
Forum|alt.badge.img+12
I want some data from the log, and I am using API to get this data anyone knows which format I use in feature reader to get the data from log file
Forum|alt.badge.img+63
The FME log files are plain text, so the TextLine reader is the best to use.
But can you tell us a bit more about what you want to do and what data you want to get out of the log?
asadamjad
Participant
  • Participant
  • Dec 6, 2022 9:06 AM UTC
I need this information in separate columns. I mean, text in separate columns and their volumes in separate columns.image
If you use FeatureWriters instead of regular writers in your workspace they'll generate a summary feature, I think that holds all the information you need and it's probably a lot easier to work with than parsing the log file afterwards.
If you want to go with the log file parsing route, I think selecting the lines using a StringSearcher (with a regex, and unfortunately I am not *that* good with regexes) should work.
asadamjad
Participant
  • Participant
  • Dec 6, 2022 9:26 AM UTC
Thanks for your response. I too not good at regex .. may be someone can help me
