How can I build a json from list with sub sub sub object ?
  • November 23, 2020
  • 40 views
geo-x
Participant
Dear FME community.
I'm trying to extract, from a json object, the json arrays.
My object looks like :
aAs you can see, I've multiple sub objects and I want to extract this parts :
aaIn this case, I tried to use the transformer jsontemplater but I was stopped by the loop in the json for sub sub object.
In this part I do this :
eeeBut maybe it' not the best method, that's why I need help.
Do you see how can I do this ?
Thank you very much.
geo-x
Participant
  • Participant
  • November 24, 2020
In fact, I try to make a loop in a loop in a loop ...
I found this solution :
"Attributes":[ 	for $Age at $pos in fme:get-list-attribute("_list{}.Age")
    		let $Date := fme:get-attribute(concat("_list{",$pos - 1,"}.Date"))
    		return {"Date":$Date"Age"$Age}]
that work for 1 sub object but for multiple sub object ??
"Attributes":[
return {
"Date":$Date"Age"$Age,
"Sub Attributes":[
for $SubAge at $Subpos in fme:get-list-attribute("_list{}.SubAge")
let $SubDate := fme:get-attribute(concat("_list{",$pos - 1,"}.SubDate"))
return {
"SubDate":$SubDate"SubAge"$SubAge,
"SubSubAttributes":[
for $SubSubAge at $SubSubpos in fme:get-list-attribute("_list{}.SubSubAge")
let $SubSubDate := fme:get-attribute(concat("_list{",$pos - 1,"}.SubSubDate"))
return {
"SubSubDate":$SubSubDate"SubSubAge"$SubSubAge,
Forum|alt.badge.img+32
  • November 24, 2020
Can you share your sample json as text rather than a screenshot?
geo-x
Participant
  • Participant
  • November 24, 2020
Thanks for your reply @ebygomm​ I've data extract join in this post :-)
