Getting FME_Encoding_Argument_Exception when writing XML file with Text Writer
zzupljanin
Forum|alt.badge.img+4
When writing XML as Text Writer I'm getting __FME_Encoding_Argument_Exception__ only in my output file. Literally only this set of string.
Why is it happening and how to solve this issue.
I'm using FME 2016.1
daraghatsafe
Hi @zzupljanin​
Out of curiosity, are there special characters in the XML? Have you tested in a new version of FME?
Regards,
Daragh
zzupljanin
  • January 15, 2021
daraghatsafe wrote:
Hi @zzupljanin​
Regards,
Daragh
Ugh, sorry for late response. I was on vacation.
I really can't know for sure if there are any special characters. Produced data can really be quite large. What special characters you had in mind? I suppose there might be those from encoding cp1250.
I hadn't tested in a new version since I have to do it in 2016 because installed FME Server is of that version.
