Get table as output from FME server app
  • February 26, 2021
  • 225 views
lambertus
Forum|alt.badge.img+15
As output from a workbench I get a table with some rows of data. This data is send to me via the Emailer.
I created a server app with this workbench and now want to get the information, which is send by the Emailer, directly as result in the Server app as a table (see attached image). The content of this table depends on the value of a Published Parameter.
I created an image which shows the idea I have in mind:
2021-02-26 14_16_00-ClipboardAny ideas?
Best answer by drc43
You could try creating the table in a HTMLReportGenerator and write it out to an HTML file. Then, when you publish the workspace to server, register the Data Streaming service and the HTML file will be streamed back in your web browser tab.
table1table2
drc43
Forum|alt.badge.img+11
  • February 26, 2021
table1table2
lambertus
  • February 27, 2021
Thanks! Works perfect 😄
