FME Desktop 2020.0.0.0: The “clipper” tool fails to proceed and gets stuck,
  • Dec 14, 2021 7:50 PM UTC
  • 112 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why the “clipper” tool fails to proceed and gets stuck,
What could be the issue here?
The workbench and data are attached
Clip_1338
Clip_1339
Clip_1336
Clip_1337
Best answer by hkingsbury
The vast majority of your geometries are Arcs, these are represented as a mathematical equation rather than a series of vertices.
After the geometry validator, add an ArcStroker to convert the arcs into lines. The process then runs in ~6 seconds
hkingsbury
Forum|alt.badge.img+73
  • Dec 14, 2021 7:59 PM UTC
jamal
  • Dec 17, 2021 9:01 AM UTC
It works like a charm.
However, I couldn’t figure out what the ArcStroker has fixed!
Clip_1344
hkingsbury
  • Dec 18, 2021 5:33 AM UTC
Clip_1344
The ArcStroker inperpolates vertices along the arc convert the true curve into a standard line
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/arcstroker.htm
