FME Desktop 2020.0.0.0: How to filter based on exact two values?
  • Dec 17, 2021 5:57 PM UTC
  • 6 replies
  • 80 views
jamal
Forum|alt.badge.img+5
For example, in the screenshot below, I wanted to filter all the values that exactly have the number “10” Or “11”.
Then why the “101”, “102”, “110” are filtered with the syntax above?
Clip_1351
Clip_1352
Best answer by geomancer
Use regex
,10$
Adding $ makes the regex look for values ending with ',10'
Maybe add a second condition (OR) for
^10,
(attribute starts with '10,').
andreaatsafe
Forum|alt.badge.img+17
Hi Jamal,
If you are wanting the Tester to find specific values, I'd recommend using the operator "=" (Equal) instead of "Contains Regex".
image-Andrea
rahulsharma
Forum|alt.badge.img+12
Hi @jamal​
Based on the screenshot, it appears that you have to adjust the tester to do the following
Adjust the Test Statement to "=" instead of "Contains Regex"
See attached workspace and screenshot Acad_TesterUpdateWorkbench (see attached)
jamal
  • Dec 20, 2021 7:04 PM UTC
Thank you for the help.
To make mor specific, in the screenshot below, I need to filter those which contains EXACTLY “,10”. This means that “,103” or “,107” shall not be filtered.
How this can be performed?
The data and workbench are attached
Clip_1393
Clip_1394
geomancer
Forum|alt.badge.img+71
  • Dec 20, 2021 7:22 PM UTC
Use regex
,10$
^10,
jamal
  • Dec 21, 2021 6:26 PM UTC
Thank you very much for the help. It works fine
Clip_1407
Clip_1408
geomancer
  • Dec 22, 2021 8:16 AM UTC
You're welcome, I'm glad I could help you.
Regex does take some getting used to.
