FME 2020: Which tool can be performed to display where the lines overlaps (duplicates) are,
  • Jan 22, 2021 7:14 PM UTC
  • 82 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out Which tool can be performed to display where the lines overlaps (duplicates) are.
For example, in the screenshot below, there are 4 lines and overlapped in the place marked in orange. How this overlap can be displayed?
the data is attached
Clip_229Clip_230
hkingsbury
Forum|alt.badge.img+73
  • Jan 24, 2021 7:26 PM UTC
SpatialRelator/SpatialFilter will be able to identify them assuming they actually touch/overlap. Otherwise another trnasformer to look at would be the NeighbourFinder
jamal
  • Jan 24, 2021 7:44 PM UTC
Thank you hkingsbury.
But how to perform this two while they require two inputs? I need to catch the duplicates within same “layer”?
Clip_257
Clip_256
hkingsbury
  • Jan 24, 2021 7:57 PM UTC
Clip_257
Clip_256
Pass the same data to both inputs
jamal
  • Jan 24, 2021 8:29 PM UTC
Thank you.
It appears that this tool doesn’t show here the overlap (duplicate) is. Am I right?
Clip_262
