Fan out to SQL Server
  • Sep 3, 2020 11:46 AM UTC
  • 5 replies
  • 157 views
robinb
Hello,
Is there a way to 'fanout' when writing to an SQL Database? The image below shows a simplified example of what I want to achieve , I have a number of target SQL Server tables and their table names relate to the values in Col2 (I actually have dozens of target tables to write to).
I'm guessing I could achieve this by writing to a format that is 'fanoutable' (e.g. Excel), then re-importing and then writing to SQL Server, but I wondered if any one knew of a more eloquent way of achieving this?
Example
Thanks,
RB
Best answer by david_r
Sure, in the output feature type parameters, set the table name to the attribute containing the table name, e.g.:
sql fanout
 As long as all the target tables have the same schema (as they do in your example), then that's all.
  • Sep 3, 2020 11:58 AM UTC
sql fanout
robinb
  • Sep 3, 2020 1:48 PM UTC
Thanks David, that is exactly what I needed.
smfks911
  • Aug 8, 2022 12:20 PM UTC
sql fanout
Hi @david_r​ , I got a similar problem where I am trying to reproject a number of SQL table and then write back to same database. The concept is like the attached image. Problem is when I am connecting all the reader tables to the projector transformer, attributes/columns from all tables are getting merged into one, from where I cannot fan out the tables to write back into the same SQL server. Is there any other interim process?sql_reproject_concept_draw
  • Aug 8, 2022 2:56 PM UTC
Did you look into using the feature attribute "fme_feature_type"? This should contain the table name from the MSSQL reader, which you can then either transform or use as-is on the writer.
Note that you may have to manually expose (make visible) this attribute on the reader first.
smfks911
  • Aug 9, 2022 12:40 AM UTC
Hi @david_r​, thanks so much. Yes I have used fme_feature_type to expose and dynamic reader/writer. That worked. Also I needed to search and replace the schema that is in string otherwise a new prefix gets added and failed to read into the destination table. Do you have any suggestion if I would like to transform tables from different schemas? The string searcher/replacer allows only one string per transformation, right?
