DataTimeConverter corrupts data !?!
  • Jun 9, 2022 7:12 AM UTC
  • 9 replies
  • 113 views
lifalin2016
Forum|alt.badge.img+42
Hi list.
I have a dataset with mixed date/time formats in a single field.
I want to create a cascade to transform these, i.e. "Try this format", and if it fails, "Try that format", etc.
HOWEVER, when data are output on DateTimeConverter's rejected port (signalling a data error), the field value is cleared, rendering a cascaded approach impossible. Why is that ??
Is there a way to avoid this unwarranted nulling of a possible valid field value ?
Cheers.
Best answer by lifalin2016
Actually, it just dawned on me, that it's defined in this file: C:\Program Files\FME 2022\transformers\fmesuite.fmx
The code seems to be Tcl/Tk, which I never really learned.
Are there any Tcl/Tk programmers out there, that may be able to decipher it and suggest a fix ?
YES!!!!
I did manage to decipher the TclTk code myself, and offer a correction.
This is the original code piece:
if {[string length $newAttrVal] == 0} {
         if {{$(PASSTHROUGH)} eq {NO} || [string length $oldAttrVal] > 0} {
            FME_SetAttribute fme_rejection_code "INVALID_INPUT";
            break;
         } elseif {!$oldAttrExists} {
            FME_UnsetAttributes $attr;
         } elseif {!$oldAttrNull} {
            FME_SetAttribute $attr {};
This is my fix:
            FME_SetAttribute $attr $oldAttrVal;
            break;
;#            FME_SetAttribute $attr {};
And it works 🙂
Now I can use the transformers in a cascading manner.
Yippee!
--------------------- edit:
Actually, the fix need only be added to the "INVALID_INPUT" block:
            break;
And the updated transformer definition can be kept in a separate FMX file in the same folder as fmesuite.fmx. Just remember to increase its version number.
  • Jun 9, 2022 7:45 AM UTC
Unfortunately this is a known issue, you'll find several threads on these forums with users jumping through hoops to work around it, e.g. https://community.safe.com/s/question/0D54Q000080hbnrSAA/datetimeconverter-rejected-port-null
It's regrettable that the issue seems to still be there in 2022.0.
lifalin2016
  • Jun 9, 2022 8:19 AM UTC
And it would such an incredibly easy fix, so why is it that hard to fix it ?
lifalin2016
  • Jun 9, 2022 8:24 AM UTC
Actually, it just dawned on me, that it's defined in this file: C:\\Program Files\\FME 2022\\transformers\\fmesuite.fmx
lifalin2016
  • Jun 9, 2022 8:59 AM UTC
YES!!!!
            break;
This is my fix:
            break;
And it works 🙂
Yippee!
            break;
  • Jun 9, 2022 9:26 AM UTC
Thanks for sharing!
DanAtSafe
Forum|alt.badge.img+23
  • Jun 9, 2022 8:07 PM UTC
FYI, the unresolved known issue is FMEENGINE-56103
lifalin2016
  • Jun 10, 2022 6:26 AM UTC
Hi Dan.
Did you see my fix ?
It's a very small thing to fix in the fmesuite.fmx file, so couldn't it, and similar fixes, be escalated to be fixed asap?
In the meantime:
Will any FMX file in the same folder be read upon start, so one can add custom updated versions as a seperate file?
lifalin2016
  • Jun 10, 2022 8:51 AM UTC
Hi Dan.
I went ahead and tried it, and yes, a seperate FMX file will indeed be read upon startup, so such customizations can be kept in its own file. Easier to distribute too.
DanAtSafe
  • Jun 11, 2022 12:22 AM UTC
Yes, I saw your fix and I've escalated the issue. Thanks!
