How can i get the data from this website via fme
https://idpgis.ncep.noaa.gov/arcgis/rest/services/NWS_Forecasts_Guidance_Warnings/NHC_tropical_weather_summary/MapServer/1
Use the "Esri ArcGIS Server Feature Service" FeatureReader or Reader.
Put
in the dataset field and choose the layers under Feature Types To Read (FeatureReader) or Parameters (Reader).
Hi @asadamjad
You can get to these features using the Esri ArcGIS Server Feature Service reader but you have to update the URL just a little:
After you select the layer that you want to explore:
Attached the Workspace. Please - check if is the layer that you want to explore.
Thanks in Advance,
Danilo
22 votes
20 votes
19 votes
15 votes
13 votes
12 votes
11 votes
10 votes
9 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
