Count unique list elements and add number of occurences to list element
lambertus
Forum|alt.badge.img+15
I have a list which contains these values:
nl restservicesMonumenten_raadplegenMapServer
nl restservicesBR_GroenstructuurplankaartMapServer
nl restservicesBijzondere_BomenFeatureServer
nl restservicesBR_BAGFeatureServer
nl restservicesVERG_TOEZOPLOSFeatureServer
nl restservicesPROJ_Mut_editFeatureServer
In want to clean up this list by removing the duplicate strings. However, I want to keep the number of times each string occures. Finally, I want to get this list which stores after each string the number of occurence as shown in my first list:
nl restservicesMonumenten_raadplegenMapServer  (1)
nl restservicesBR_GroenstructuurplankaartMapServer   (2)
nl restservicesBijzondere_BomenFeatureServer   (1)
nl restservicesBR_BAGFeatureServer   (2)
nl restservicesVERG_TOEZOPLOSFeatureServer (4)
nl restservicesPROJ_Mut_editFeatureServer   (5)
Any ideas? I have tried something with an AttributeSplitter folllowed by a ListHistogrammer which leads to two lists. However, I was not able to combine them so far.
Best answer by ebygomm
You could explode the list after the ListHistogrammer, create the new text from the name and the count then rebuild the list
Capture
Forum|alt.badge.img+34
  • March 8, 2021
Capture
  • March 8, 2021
Working with lists generally is one area where doing something in python can be more straightforward than using FME. This would take a list called list{} and replace it with a list of the same name but removing the duplicates and adding the counts
import fme
import fmeobjects
from collections import Counter
def processFeature(feature):
    #get list item
    mylist = feature.getAttribute('list{}')
    #set count
    count = 0
    #remove original list now stored in mylist
    feature.removeAttribute('list{}')
    #use Counter to count occurrences of value in list and iterate through
    for k,v in Counter(mylist).items():
        count +=1
        #set newlist attribute
        feature.setAttribute("list{"+str(count)+"}",k + " ("+str(v)+")")
 Capture
lambertus
  • March 8, 2021
Capture
Thanks, works perfect!
