Copy/paste shortcuts not working in 2022.1
  • Oct 6, 2022 4:03 PM UTC
  • 8 replies
  • 164 views
mcannalea12
Has anyone run into CTRL+V not working in 2022.1? Seems to be okay within transformers but I can't use a shortcut to copy and paste a transformer itself. What's weird is if I use CTRL+C, the paste icon above correctly pastes the transformer. Just can't use the CTRL+V shortcut. Worked without issue in 2021.
Forum|alt.badge.img+63
Haven't come across this one myself. What build are you using? And you're on Windows, right?
caracadrian
Forum|alt.badge.img+23
  • Oct 7, 2022 11:04 AM UTC
I know this sounds weird, but have you tried turning it off and on again?
Try installing a different build.
mcannalea12
  • Oct 7, 2022 12:47 PM UTC
Yes, Windows and I'm using Build 22627.
nielsgerrits
Forum|alt.badge.img+67
I have a coworker using FME(R) 2022.1.3.0 (20220928 - Build 22630 - WIN64) having this same problem. CTRL-D (duplicate) works fine.
On my machine, running the same build, it just works fine...
*** update 20221017 ***
Issue at coworkers machine went away after a reboot.
gisbradokla
Forum|alt.badge.img+27
  • Oct 17, 2022 2:31 PM UTC
we have the same problem. on different workstations. and yes when you close. it MAY start working again.
stephstedman
Forum|alt.badge.img+7
To add that I am also having this problem, CTRL-C works but not CRTL-V 😂
ctredinnick
Forum|alt.badge.img+22
  • Aug 10, 2023 12:16 AM UTC
I have 2022.2 Ctrl+C works for copy, Ctrl+V does not work for paste. I have gotten in the habit of right clicking on the canvas to paste a transformer
westerbrink
Forum|alt.badge.img+4
  • Sep 14, 2023 12:42 PM UTC
Same here with FME Desktop 2022.2.6.0 (20230523 - Build 22800 - WIN64).
If Ctrl+V doesn't work I usually use Ctrl+D instead (haven't used that shortcut in versions prior to 2022) or by right clicking indeed.
