Configuring the JSONTemplater
nedwaterman
Forum|alt.badge.img+9
Hi all,
I'm having issues configuring the JSONTemplater to output my data.
I currently have 7 rows, with 2 unique IncidentIDs. I'd like to aggregate the postcode data and geometry for these 2 IncidentIDs so that the json can be used on a webmap showing all the postcodes associated with an incident:
imageI've configured my ROOT and SUB templates but the JSONTemplater fails at the root. Can anyone see what I am doing wrong?
imageROOT:
{ "type":"FeatureCollection",
"features":
fme-process-features("SUB")
SUB:
    "type":"Feature",
"properties":{"Postcode":fme:get-attribute("POSTCODE")},
    "geometry": {fme:get-json-attribute("_geometry")}
Thanks in advance
N
Best answer by takashi
Hi @nedwaterman​ ,
The reason for the error in the Root expression is a typo in the function name.
wrong: fme-process-features("SUB")
correct: fme:process-features("SUB")
However, if you intend to aggregate Polygons to form a MultiPolygon for each Incident_ID, I don't think JSONTemplater works as expected.
In that case, I think you can create polygon geometry from the "_geometry" attribute value with GeometryRelacer, aggregate the polygons with Aggregator grouping by Incident_ID, then write the features with GeoJSON writer.
nielsgerrits
Forum|alt.badge.img+54
With these settings it works for me:
ROOT
	"type": "FeatureCollection",
	"features": [fme:process-features("SUB")]
SUB
	"type": "Feature",
	"properties": {
		"Postcode": fme:get-attribute("POSTCODE")
	"geometry": fme:get-attribute("_geometry")
  • October 22, 2023
Hi @nedwaterman​ ,
nedwaterman
  • October 23, 2023
takashi wrote:
Hi @nedwaterman​ ,
Thanks both for your help - much appreciated!
