ChartGenerator doesn't seem to honour the 'fill' line colour. Anyone else have this problem?
Build: 2020.1.2.1 (20200909 - Build 20624 - WIN64)
Hi @kieranmg
Could you share us the log file from FME Desktop?
Is better to check this problem.
Thanks in Advance,
Danilo
2020-10-07 11:25:50| 0.6| 0.0|INFORM|mapping file Line 330: `FACTORY_DEF' `*' `BreakpointFactory' `FACTORY_NAME' `AttributeManager_OUTPUT Break Point -1 48' `INPUT' `FEATURE_TYPE' `AttributeManager_OUTPUT' `ID' `48_Main' `NAME' `AttributeManager [AttributeManager] : Output -> ChartGenerator [ChartGenerator] : Input' `ENABLED' `no' `ACTION' `BREAK' `OUTPUT' `OUT' `FEATURE_TYPE' `*' `@LogCount(LINK -1 48)'
2020-10-07 11:25:50| 0.6| 0.0|INFORM|mapping file Line 331: `FACTORY_DEF' `{*}' `TeeFactory' `INPUT' `FEATURE_TYPE' `AttributeManager_OUTPUT' `OUTPUT' `{' `FEATURE_TYPE' `ChartGenerator_PROCESSED' `fme_cg_chart_type' `Line' `fme_cg_chart_title' `Timboon<space>-<space>Camperdown<space>Railrail<space>Elevation<space>Profile' `fme_cg_chart_setup' `XATT;intervals;YATT;_z;EATT;;COLOR;0.792157,1,0.717647;LINE_STYLE;DOTTED;LINEWEIGHT;1;FILL_AREA;YES;DISCRETE_X;NO;DISCRETE_Y;NO;POINT_STYLE;NONE;LABEL_ANGLE;H' `fme_cg_x_label' `Distance<openparen>km<closeparen>' `fme_cg_y_label' `Elevation<openparen>m<closeparen>' `fme_cg_multi_ds' `NO' `fme_cg_legend' `<Unused>' `fme_cg_legend_options' `NO' `fme_cg_x_min' `' `fme_cg_y_min' `' `fme_cg_x_max' `' `fme_cg_y_max' `' `fme_cg_axes_lw' `0.5' `fme_cg_axes_font' `Arial<comma>12' `fme_cg_title_font' `Arial<comma>12' `fme_cg_legend_font' `<Unused>' `fme_cg_tick_font' `Arial<comma>10' `fme_cg_background_color' `0.858824<comma>1<comma>0.988235' `fme_cg_ticks' `G' `fme_cg_x_log' `LIN' `fme_cg_y_log' `LIN' `fme_cg_data_series' `' `fme_cg_xtick_interval' `' `fme_cg_ytick_interval' `' `fme_cg_x_inch' `15' `fme_cg_y_inch' `2.0' `fme_cg_dpi' `300' `}'
2020-10-07 11:25:50| 0.6| 0.0|INFORM|mapping file Line 332: `FACTORY_DEF' `*' `PythonFactory' `FACTORY_NAME' `ChartGenerator' `INPUT' `FEATURE_TYPE' `ChartGenerator_PROCESSED' `PYTHON_NAMESPACE' `FMEOBJECTS' `SYMBOL_NAME' `chartgenerator.ChartGenerator' `OUTPUT' `PYOUTPUT' `FEATURE_TYPE' `ChartGenerator_OUTPUT' `@RemoveAttributes(fme_cg_chart_type,fme_cg_chart_title,fme_cg_chart_setup,fme_cg_x_label,fme_cg_y_label,fme_cg_x_size,fme_cg_y_size,fme_cg_group_by,fme_cg_multi_ds,fme_cg_legend,fme_cg_x_min,fme_cg_y_min,fme_cg_x_max,fme_cg_y_max,fme_cg_axes_lw,fme_cg_axes_font,fme_cg_title_font,fme_cg_legend_font,fme_cg_tick_font,fme_cg_background_color,fme_cg_ticks,fme_cg_x_log,fme_cg_y_log,fme_cg_data_series,fme_cg_xtick_interval,fme_cg_ytick_interval,fme_cg_out_scheme,fme_cg_x_inch,fme_cg_y_inch,fme_cg_dpi)' `@ReinterpretRaster(RASTER,RGBA32,AVERAGE,DROPALPHA,TYPESCALE,BOUNDED_CAST,DATASCALE,BOUNDED_CAST,ROUND,CREATEOPAQUEALPHA)'
The preview is the same as the writer output, dark-grey instead of green
24 votes
20 votes
14 votes
12 votes
11 votes
10 votes
9 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
