Cannot connect
  • September 13, 2022
  • 46 views
I haven't yet seen this - I cannot connect 2 transformers.
It seems like there is something downstream the flux that prevents the connection.
I captured the behavior in gif:
FME-workbench-impossible-connectionI have Workbench 2020.0.1.
Thanks in advance for any suggestions!
dustin
Forum|alt.badge.img+30
  • September 14, 2022
You probably have a loop somewhere in your transformers. Follow the connection from the FeatureMerger_flux to see if any make their way back to FeatureMerger_data. You'll need to correct that somehow. The only way to loop data in a workbench is within a custom transformer.
