Administering ArcSDE with FME
  • Nov 21, 2020 4:32 AM UTC
  • 21 views
I currently administer an ArcSDE database and have most things automated with Python and task scheduling. This works well but it is far from transparent and simple, and I feel I could use FME to automate the entire process. I'm thinking that while some of the process could be handled with the inbuilt transformers I would definitely still need to utilise ArcPy for most tasks and so would rely heavily on the PythonCaller transformer.
Is this an avenue I should explore, or is this best dealt with another way? Has any one else successfully done this, and if so are there any examples available?
Thanks in advance.
Nathan
hkingsbury
Forum|alt.badge.img+73
  • Nov 22, 2020 6:54 PM UTC
You could also look at the systemCaller and call external python scripts
