2018 inspector takes forever to open, what can I do?
  • Mar 27, 2018 6:56 PM UTC
  • 50 views
After I've run a workspace with FME 2018, the inspector takes like forever to start. Anything from several minutes to forget-about-it.
For compability reasons, I have multiple FME installations at my windows 7 corporate PC (which is a pretty hardcore piece of a machine (32gb ram, ssd, plenty of processing power) - if this machine can't run it, nothing can). No issues so far - except that the 2018 inspector will either give up completely or take minutes to show the data I've piped into it.
FME 2017 and older seems to work fine.
Unless a lot of other people are complaining, I guess there must be something fishy with my setup. Any ideas welcome.
  • Mar 28, 2018 7:55 AM UTC
For what it's worth, on my pc the 2018 Data Inspector is as quick as the 2017 one.
Forum|alt.badge.img+63
First thing I would try is re-install FME 2018 and see if the problem persists.
Weird. Everything's back to normal behaviour. (And yes, I did restart my computer before asking).
As always, we fall back to the default for this kind of funky behavior: Blame it on Windows.
