I'm trying to set up an automation on FME Cloud where the trigger is an UDP message. I have tried several configurations and I'm testing with an UDP sender tool but I can't seem to receive anything.
  • January 15, 2021
  • 5 views
jatoxa
Forum|alt.badge.img+12
I have set up static IP adress for the cloud instance as I assume this is necessary?
Best answer by jatoxa
I figured it out. I set the source under Permissions to the correct port and added "0.0.0.0/0" as IP adress. Now it works perfectly.
jatoxa
  • January 15, 2021
