Our FME License server run on LMTools by Flexera doesn't read the option file safe.opt.
The safe .log file gives the following log:
xx:xx:xx (safe) CANNOT OPEN options file "="
The safe.opt file is at the same location as the license safe.lic file. Rereading the license file doesn’t seem to work.
I don’t see anywhere else in LMTools where you can configure this. Is their a command line tool with lmutil or lmgrd that adds the option file to the license server config?
