Errow with running my FME Flow
evoteck
Forum|alt.badge.img+13
The above error is the error am having running a workspace on FME Flow.
Log Error
The log file for job ID "6" does not exist.
Best answer by nielsgerrits
It is not really an error, but yes, without an engine, FME server will not process a job.
nielsgerrits
Forum|alt.badge.img+54
I think the job is queued? There will only be a log when the job is started.
evoteck
  • April 15, 2025
Yes it’s queued, but when I click on on the workspace, it shows the error  (The log file for job ID "6" does not exist.) which I have tried it many time.
nielsgerrits
Not sure if I understand your question, but I think you want to know why server does not start processing the job.
On the left side of the screen, engine management, engines. Do you have any active engine?
evoteck
  • April 15, 2025
I have not setup the engine at the left-hand side, I think I need to do that.
evoteck
  • April 15, 2025
could the Engine be the cause of the error ​@nielsgerrits
nielsgerrits
  • April 15, 2025
