Writing to SDE, get error with feature caching off, works with feature caching on!
oliver.morris
Forum|alt.badge.img+12
I have spent most of the morning going down a rabbit hole and really am none the wiser. I am writing out some content to a feature class in SDE. When I run the full process with feature caching on or off I get a failure to write with a very unhelpful ESRI error:
An error occurred while attempting to insert a row into the table 'DBO.xxxx' using a cursor. The error number from ArcObjects is: '-2147418113'. The error message from ArcObjects is: {}
However if I run it with feature caching on, up to the last transformer and then run to the writer afterwards the content goes into the SDE, no error.
If I write to a ffs file then push that to sde. It works.
My suspicion is that I am using a feature reader, it seems like SDE doesnt recieve all the right info about the schema before FME tries to write to it, whereas it does when feature caching is enabled?
Any ideas very much appreciated.
Thanks
Oliver
Best answer by ebygomm
I've seen the same 'helpful' error recently, although the circumstances were slightly different. What do you have your python compatibility set to?
Forum|alt.badge.img+34
  • June 22, 2020
oliver.morris
  • June 22, 2020
3.7+ at the moment. Thanks for the help.
oliver.morris
  • June 22, 2020
I changed to ESRI Pro 2.1-2.5 (Python 3.6) and this sorted the issue bizarre. Wow, only lost a days work debugging this. Thank you so much for the help @ebygomm
  • June 22, 2020
The answer provided by @markatsafe here resolved the issue for us
https://knowledge.safe.com/questions/108266/sde-write-error-2147418113.html
